Projects: Chevy 93 K1500 - Trucks 4x4 @ Off-Road.com
Trucks & 4x4 Jeep Diesel ATV & UTV Dirt Bike Competition Snowmobile Business
Trucks & 4x4 »
Price and Compare Vehicles:
New, Used, and Powersports    Go button
  • Project K1500: Posi-Lok or Bust
    4x4 Posi-Lok makes an alternative front axle engagement system. This setup, referred to as the Posi-Lok, is 100% mechanical.
    Project K1500: Electric Fan Install
    After searching far and wide I finally found a solution for keeping my engine running cool - switching to an electric cooling fan from the stock clutch-driven mechanical one.
    Project '93 K1500: Tom Wood's Custom Drive Shaft Install
    Off-Road.com shows you how to install a Tom Wood's Custom Drive Shaft on your 4x4.
    Project K1500: Richmond Gear and Powertrax Extreme Traction System
    After upgrading to the 35-inch Pitbull Rockers the truck has been crying for a gear change.
    Transmission Overhaul Part III - Home Sweet Home
    Our Chevy truck gets a new torque converter, deeper transmission fluid pan, and final assembly by AAMCO.
    Project K1500: Transmission Overhaul Part II Dissasembly
    Once I got project '93 k1500's transmission apart I decided it might be best that I left it to professionals at my local AAMCO to reassemble.
    Project K1500: Transmission Overhaul Part I Overview and Detachment
    About 210,000 miles later I have finally decided to direct my attention to the transmission. It is the original, stock tranny that came with the truck all of about 14 years ago and has not had any complications.
    Low-Cost Bed Liner for your C/K Series Chevy Truck
    Adding a custom yet cost effective bedliner would help preserve the life Project '93 K1500's bed.
    Operation Ground Clearance
    After our trip to Flat Nasty about a month ago we determined that installing a body lift and forcing the largest tires possible did not provide satisfactory ground clearance. For obvious reasons it appeared that we were in serious need of a suspension lift.
Untitled Document
Need Gas Mileage & Power?-
Stickers, stickers, stickers!-
You don't have to beg - you can get them for free! Just simply register and Off-Road.com will send you stickers from our participating companies. It's free and easy, so slap them on your ride, house or friends. Click here to register and get sticky...
Off-Road Videos -
ATV Reviews -
In the Business of Off-Road?-
If you work in the off-road industry, you need Off-Road Business! Our magazine, eNewsletter, and website give you the latest industry news, new product reviews, and business tools and services you need to succeed! Check out OffRoadBusinessMag.com!
Enewsletters
Stay on Top of All the Action:
Sign up for Off-Road.com's Enewsletters
Click here
